Just wondering if anyone knows what type of Big Block valve cover gasket is used for 71 454. April car.
Was it the silver painted cork or plain cork
Would the top of the gasket tab be painted orange and the bottom edge of the gasket would be left original and unpainted.
Or the valve cover gasket is totally left unpainted,
Would the sequence of putting the valve covers on the engine, They painted the valve covers first then they added the valve cover gaskets and bolted it on....I don't think GM would waste their time in doing this. I would figure they would put on the unpainted valve cover, then the gasket on, then the reinforcement tabs then the valve cover bolts, bolt it on and spray the engine orange. Then add the carb and fittings.
The TIMJ guide has no reference to the valve cover gasket used
Thanks for your help as I am trying to get the engine done.
Grant
Grant
