67 Goodyear original spare tire - NCRS Discussion Boards
  • Ken G.
    Infrequent User
    • 13
    Got a lead a spare. Does this sound like an original?
    the front outer side has these markings; goodyear polyesther cord 7:75 4ply rating 2 ply power cushion and a diamond with 3t inside, close to the bead of the tire has; meets rma-a&sae j918a vi in circle. on the rear sidewall has as follows, outer edge has, goodyear polyester cord 7:75-15 replaces 6:70 15 power cushion, at the inside bead, power cushion-tubless 4 plyrating-2 ply #213567 7:75 goodyear meets rma-1&sae j918a serial # number? stamped ya17g77, on the flat surface of the inside bead has an mr-16771b molded in. 5/8" whitewall
    No mention of any DOT markings.
    What do you guys think?
  • Steve B.
    • March 1, 2002
    • 1190
    Re: 67 Goodyear original spare tire
    If I am reading your post correctly, the tire is a goodyear power cushion. If so, I believe it is a correct tire for a 67.
    • Mark D.
      • June 30, 1988
      • 2142
      I thought they were nylon cord, not polyester.
      Kramden
