How can I find out what type of valve covers came from the factory in 1965 on 327 carb. with 4 speed, I've seen some with red/orange steel and others with aluminum. Which is correct?
65 Valve Covers
Re: 65 Valve Covers
Hi Michael,
I believe there is also some differences in the aluminum ones. i cannot remember, but some years had a visible line running through the "O" from a mold defect.
If you are looking to have the car judged you may want to check this before purchasing a set.- Top
Re: 65 Valve Covers
And, not all the stamped steel covers look alike. Check the area just outside the ends of the rectangle that holds the 327 sticker (or decal). The discussion archives probably holds some details that I cannot remember at the moment...https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
Re: 65 Valve Covers
The line is from where the mold was broken and then repaired. I don't remember whether this was in late 65 or in 66, but it is in the archives.Hi Michael,
Re: 65 Valve Covers
Hi Michael,
The defect actually began during the 66 model year. 65 should not show the casting flaw.- Top
