67 instrument cluster restoration - NCRS Discussion Boards
  • Ron N.
    • August 18, 2008
    • 243
  • Michael H.
    • December 1, 1987
    • 724
    Re: 67 instrument cluster restoration
    I had Corvette Specialist of Maryland do mine, I'm very happy with the results.
    Mike
    • Dennis B.
      • May 31, 2004
      • 174
      I had my '66 cluster and clock done by Jim Harrison. Beautiful and professional work. No better place IMHO.
      This website is for sale! harrisonspeedometer.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, harrisonspeedometer.com has it all. We hope you find what you are searching for!
      Dennis
      • Domenic T.
        • January 29, 2010
        • 2452
        Ron,
        I am doing my 67 speedo and cluster.
        The speedo is very simple to work on and all is visible so you can see if there is a failure or if it's just gummed up.
        Mine stuck from sitting and even has the speed warning along with the trip odometer and all it needed was cleanind and the right lube.
        We tested lubes in the shop years ago to see what gummed up whith time, marvel,WD40,3in1,all but the newer synthetics.
        We put them on a tin and then on the roof in the sun for a year or so and the only one that stayed the same, color and all was ATF.
        I lubed my clock that was having trouble and it snapped back into action, I then cleaned the points and it works great.
        Pledge works great on the face and plastic.
        If you can pull the cluster, I'll bet you can fix the speedo.
        DOM
