54 manifold heat valve - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Hi, is the valve supposed to move freely? mine only moves with firm pressure, can you take this off with it on the car, maybe tapping it with a punch (what side) and what to do to free it up? Thanks again, Brad.
  • John L.
    • February 1, 2005
    • 207
    Re: 54 manifold heat valve
    Hi Brad,
    I will defer to others more experienced but it is my understanding that at some point early in production it was determined the heat valve was not needed and thus a "block off" plate was installed between the exhaust manifold and intake. On my 54' I did not bother getting this to turn but made sure it looked ok from the outside. Lets see if I am correct on this or not.
    Good luck!
    John Lanning
    • Brad H.
      • August 12, 2007
      • 724
      John, I remember that also, mine being stuck in the closed position (I think) has turned my Manidold white, does this hurt anything? or a less vaccum( wipers are slow) if the valve moves freely does it effect anything? I want to do the as most have done, anyone else please chime in if you would, thanks, Brad.
      • Chris S.
        • January 1, 2000
        • 1064
        the valve should move freely
        yes - there is a block off plate that goes between the Intake and exhaust manifold
        It will not affect the wipers - wipers work off intake vacume
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Brad H.
          • August 12, 2007
          • 724
          Hi Chris, can I free that valve up in place and if so will it tap out, and if so is there a pin or shaft that can be cleaned up so as to rotate freely? thanks again, Brad.
