60 brass wire ties - NCRS Discussion Boards
60 brass wire ties
  • William B.
    • April 30, 1975
    • 939
    60 brass wire ties
    I have a 60 fuel car without windshield washers. I believe there should be 2 brass wire ties in the front headlight wiring area around the wires left and right side. Can anyone describe where or show a picture?
    Also I do not have windshield washers do I need brass wire ties in the firewall wiring, if so where?
    Thanks for anyone's help, Bill
  • William B.
    • April 30, 1975
    • 939
    Re: 60 brass wire ties
    Does anyone have an answer?
      William -
      What's shown in section 12 of your 1960 Assembly Manual?
      • Dennis C.
        • June 30, 2002
        • 884
        William,
        I don't have a 1960 AIM but check the sheet for the heater hoses. Later models have a tie on them that I think is just forward of the generator.
        I don't remember any other.
        Dennis
        • Donald H.
          • November 2, 2009
          • 2580
          See the AIM section 12 sheet 2. There are four brass ties. Two around the wire harness in the front, I. E. the headlight, park lights and horn wires. There are also two under the dash around the wire harness. There is also a plastic tie above the steering column holding the turn signal wires and the windshield cable. The last one I found a picture in the 58-60 Corvette Restoration Handbook
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • William B.
            • April 30, 1975
            • 939
            Have previously looked at the aim, not clear was looking for a picture of an origional car.
