1965 frame paint or power coating - NCRS Discussion Boards
  • Ralph A.
    • May 15, 2007
    • 117
    corvette 003.jpgHi Guys just got my frame back today from getting it dipped, Now what should be dun power coating or paint remember I am trying to get my car judged thanks Ralphcorvette 001.jpg
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1965 frame paint or power coating
    Originally posted by Ralph Amitrano (47366)
    [ATTACH=CONFIG]39578[/ATTACH]Hi Guys just got my frame back today from getting it dipped, Now what should be dun power coating or paint remember I am trying to get my car judged thanks Ralph[ATTACH=CONFIG]39579[/ATTACH]
    No powder coating if your having the car judged. After having my frame stripped shot self-etching primer on it, then low sheen chassis black.
    • Ralph A.
      • May 15, 2007
      • 117
      Hi Michael the guy who's doing the job wants to power coat, then paint over the power coating with correct color black paint what do you think.
      • Michael G.
        • January 1, 1997
        • 1251
        Unsure of this rational as IMO an unneeded process and expense. I've done numerous frames using the aformentioned process....still look good 15+ years later.
        • Russ S.
          • April 30, 1982
          • 2161
          I like powder coating but I also see no reason whatsoever to paint over PC. Eastwood chassis black primer and paint is a good product.
          PS. If one was to paint over PC, you would need to scuff sand the PC.
          • Ralph A.
            • May 15, 2007
            • 117
            do they make PC the correct color black
            • Russ S.
              • April 30, 1982
              • 2161
              I suppose it would depend on how many choices your powder coater has but the ones I have been to have four or five to choose from. I would say yes.
              • Wayne G.
                • April 30, 1984
                • 143
                Ralph,
                I think you have to decide if you want your restoration to look like the way Chevrolet built the car or your version of that. Chevrolet never powder coated anything and if you check closely on the high end restored Corvettes, they were done the way Chevrolet built the car in the first place. There is a big difference in finishes.
                Check out the cars that are resorted correctly and make your decision .
                Wayne
                • Gene M.
                  • April 1, 1985
                  • 4232
                  I guess if you apply the CDCIF deduction standards the powder coat you could lose 20% for finish. Assuming everything else is good. Keep in mind that the total points for the frame is about the same value as the wiper motor. Even if you had a fabricated tube frame with every thing mounting to it as original the deduct would not be that much. Seems a bit goofy for a piece so big and major to the car but by the points not a big deal.......!
                  • Paul J.
                    • September 9, 2008
                    • 2091
                    Ralph, why would you want to powder coat the frame? Are you going to be driving it in a lot of salt and ice? If you're concerned about a salt air environment, there is no difference in corrosion protection between PC and paint. In addition, when PC chips, the repair is to fill the hole with paint. Finally, does it matter to you that PC leaves a much thicker and detectable coating?
                    As I've said many times before, powder coating gives an extremely durable finish, but it has no place on a classic car and certainly not on one that is not driven very often.
                    Paul
                    • Wayne G.
                      • April 30, 1984
                      • 143
                      Ralph,
                      As Paul said,why would you powdercoat the frame if the car is being restored for use in flight judging? You will be much better off in the long run to restore the car back to the condtion it was when GM built it. If you can find a copy of David Burroughs book,"Corvette Restoration Sate Of The Art" buy it and follow his restoration method. You'll Top Flight without issue.
                      Good Luck.
                      Wayne
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        Wayne,
                        Thanks for the tip. I had not seen that book before. I found it easily enough on Amazon.com. I look forward to reading it when it arrives.
                        Joe
                          • 11608
                          Originally posted by Joe Raine (45823)
                          Wayne,
                          Joe
                          Though a bit dated now it's an excellent book.
                          The first time I read it (early 90s) I sent David Burroughs a note and he called me to discuss the book to discuss the book and the car. Nice guy, too.
                          • Nick M.
                            • January 1, 2005
                            • 58
                            I looked on Amazon for the book by David Burroughs book,"Corvette Restoration Sate Of The Art"
                            The only one I found is by Michael Antonick, is this the same book you are referring to??
                            • Wayne G.
                              • April 30, 1984
                              • 143
                              Michael Antonick did write the majority of the book with the assistance of David Burroughs. This may help, the book was published by Michael Bruce Associates Inc.
