Inner fender well flap installation for a 1966 - NCRS Discussion Boards
  • Douglas G.
    • April 30, 2001
    • 58
    How many staples were used per flap? Placement of the staples. Were staples crimped on the engine or fender well side?
    Any suggestions on how to crimp the stainless steel staples that are supplied ie tool to use? Thanks for any help.
    Doug
  • Alan D.
    • January 1, 2005
    • 2027
    Re: Inner fender well flap installation for a 1966
    Doug see your AIM, try section 11-13 sheet A2.00 (that's the 64 page) That gives you a ball park on number & placement.
    Remember to put staples in from engine side and clinch in the wheel well area. Toss the stainless staples - not original, but worst yet very hard to clinch. Do a search on subject since other members have come up with methods to clinch (its a PITA)
    Remember they get painted blackout.
    • Domenic T.
      • January 29, 2010
      • 2452
      Douglas,
      I finished mine about 3 weeks ago but had the old inner fenders to go by.
      I threw away all the provided staples away because they were not correct, BUT I did use SS wire and made my own staples.
      The wire was .041 SS safety wire used on aircraft. It was about .006 les diameter than the ridged steel staples and easy to bend.
      I drilled 2 holes in a flat piece of metal as a drilling referance to get the holes right. sloppy seemed to be the way they were done.
      DOM
        Doug -
        I've always made my own staples from 16-ga. steel wire (hardware store blister-pack item).
        • Russ S.
          • April 30, 1982
          • 2161
          Doug, When you get the staple thru the holes, use a needle nose pliers and grip the staple leg at the point and twist it into the configuration it was originally. I find with a bit of practice it actually become quite easy and fast.
          • Jack C.
            • September 30, 1992
            • 1090
            Don't forget to paint the staples since they were installed before engine bay blackout.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
