Replacing Road Draft Tube on 1960 - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1338
    Any advice before I start to change out the incorrect tube with the correct tube? The motor is in the car. I envision the following steps:
    remove the top ignition shielding
    remove the rear bolt that connects the ignition shield top to the vertical shielding
    remove the clamp from the starter bolt
    remove the bolt out of the top of the road draft tube
    slide the rubber spark plug wire holder out of the road draft tube slot
    slide the old tube down the side of the block and off
    make sure the spark plug wire holder on the correct tube is bent the same angle as the incorrect tube
    slide the correct tube up the side of the block into place
    reverse the other steps
