1960 antenna - part number - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    I am trying to confirm the part number for antenna mast for my 1960.
    Is # 3756683 corrrect? (three section / 21" long fully retracted)
  • Tom D.
    • September 30, 1981
    • 2126
    Re: 1960 antenna - part number
    Assembly Manual (in the back pages, with the Options) says 3726293.
    My June 1979 Parts Book, printed by GM, does not list a replacement in group number 9.something...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Daniel J.
      • July 29, 2007
      • 158
      Tom:
      Is that part number for the mast only or the whole antenna assembly?
      Thanks, Dan
        Daniel-----
        GM #3756683 was an antenna mast applicable in SERVICE to many Chevrolet models, including many C1 Corvettes. However, I do not know if it was the same as the mast used in PRODUCTION for all those applications.
        • Dan A.
          • May 31, 1974
          • 1074
          1958 through 1963 P&As list the 56-7 antenna unit as part #3727578
          1958 through 1961 P&As list the 58-60 antenna unit as part #987861, then it appears to drop off the map while the 56-7 antenna unit contiues.
          I jumped to the October 1968 P&A and the solid axel part numbers did not appear.
          Jumping forward again the 1975 P&A lists a group 9.647 for the "rod and mast". I did not look to see when that goup number started, but it does not exist in the earlier parts books, only group 9.645 wHich lists antennas as units.
            Dan------
            Most radio-related parts are not included in earlier P&A Catalogs. They are in a separate Radio Parts Catalog. Even later P&A Catalogs only include a small number of the radio-related parts.
