C-1 Rear crossmember - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Noticed that Corvette Central has listed rear crossmember for 53-57 and 61-62 as one part number and 58-60 another part number. Anyone know the difference? Thanks in advance.
  • Al E.
    • September 5, 2011
    • 313
    Re: C-1 Rear crossmember
    yes... one has extra holes for the rear bumper brackets.. I just bought one last week for my 1960 it is very heavy duty stuff. it comes as raw metal so you will have to clean it with a metal cleaner to remove the machine oil and paint it.
    AL
    • Brandon T.
      • October 23, 2008
      • 872
      Do you know if the rivets that holds the rear crossmember in place go in from the top or bottom?
      • Brandon T.
        • October 23, 2008
        • 872
        I ordered one for my 58 but it only has 7 holes and my old one had 9 holes. Do you know how many holes it suppose to have?
        • Donald H.
          • November 2, 2009
          • 2580
          I believe the head of the rivet is on the bottom. That's the way I did mine. I used acetylene torch and a home make bucking tool to set the rivets. Picture attached.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • Steven B.
            • June 30, 1982
            • 3976
            See Al's reply for number of holes. The head faces down toward the pavement. GM replacement parts decades ago superceeded the earlier piece with the '58 up piece.
            • Joe M.
              • February 1, 2005
              • 589
              two versions
              • Brandon T.
                • October 23, 2008
                • 872
                Thanks for the picture. I had to drill the holes on each end near the leaf spring brackets. Not sure why the new one didn't come with holes already drilled.
