Engine starts up great when cold. After running and shutting down engine is hard to start and appears to be flodding. Engine running very cool with ambiant tempertures in 70's but have a suspicion that the gas is boiling in carb causing hard start. I don't see an insulator listed for this enginein the AIM manual. Any suggestions?
427/425 flooding
Re: 427/425 flooding
Engine starts up great when cold. After running and shutting down engine is hard to start and appears to be flodding. Engine running very cool with ambiant tempertures in 70's but have a suspicion that the gas is boiling in carb causing hard start. I don't see an insulator listed for this enginein the AIM manual. Any suggestions?- Top
I plan to do that, too. To expand on your suggestion, wire the heat riser open and only block the driver's side. That way a little heat gets to the carb when starting cold. But since there is no air flow, less heat is transferred to the carb. Which makes more horsepower and helps keep the carb cooler for hot start issues.
Joe- Top
Clem,
Joe- Top
Remember that your choke is operated by a remote thermostatic coil mounted on the intake manifold; if you block the heat riser passages on both sides, it'll take a LONG time for the choke to open, if it ever opens fully at all. If you only block the one on the driver's side, you should get enough heat to the choke thermo coil to fully open it, but it'll take longer than normal. In either case, you can wire the heat riser valve open.- Top
i ran all my HP chevys with the heat risers blocked both sides and even in Pa. winters. i just disconnected the choke and gave the engine a couple of pumps to the gas pedal,waited 10/15 seconds for the gas to vaporize and fired it up.- Top
