Just purchased a new deWitts radiator for my 57. I also got a new ID tag. Where does the tag mount? Is it painted? What's the best way to mount it? Thanks.
radiator tag placement
Tags: None
- Top
Re: radiator tag placement
The tag mounts on the back surface of the top tank centered from left to right and top to bottom.
I think I mounted it with JB Weld, and it's been on for a couple of thousand miles and is still tight.
It is painted black the same as the radiator.- Top
Stephen, make sure it's above the radiator shroud. Bottom of the tag is right above the edge of the shroud. Gary....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
John it is one of the direct fit models. Hope to get it in this weekend. So don't know about fit yet. Thanks for the reply.- Top
all 55-60 direct fit radiators come with a 58-60 mounting strap. on a 58-60 corvette the radiator will bolt like the original. 55-57 corvettes had a mounting strap that was one inch higher and the direct fit radiator will not have the upper hole and tacked nut on the bracket.- Top
