Something to watch for...............
I noticed recently while having some wheel/tire assemblies balanced at the tire shop for a 58, ( they have the latest and greatest balancing equipment) that the operator of the machine was using a fixture that located wheel center using the 5 lug holes. It did NOT even touch the ID of the inner hub hole
I stopped him and questioned why he was not using the spindle and tapered fixture I was accustomed to seeing that located center using the hub ID and he said that is what he was taught to do and he did all wheels this way.
I thought for a moment and realized that lots of the aftermarket rims sold today do not use the hub hole at all and actually if buying a say, repo rally from one of many suppliers/distributors that the hub hole diameter is actually much larger and does not locate the rim on center using the hub of the vehicle. They actually locate center only with the lugs. I never did like that but now I see why the tire balancing equipment was designed to accommodate that.
The way I see it, the weight of the car is supported by the hub in the wheel, the lug nuts merely hold the wheel against it. The newer wheels are actually using the lug nuts to do both.
But that is not the way our wheels were designed.
A wheel manufactured 40-50 years ago that was designed to locate center with its hub locating hole better be balanced by finding center with that same hole. Or it may not balance properly.
These old rims have had a lug nut tightened into its tapered hole many, many times, potentially spreading it, or distorting it, so I really did not think using them to center the wheel for balancing was a good idea in this case
I am sure wheel manufacturing equipment is much more precise these days, but to me, I want my wheels solidly located on the hub.
I insisted he find an adapter to do so, and he did.
