They are from a 1972 small block, have been sitting in my basement for 40 years. Can you buy the correct springs anymore
Are original pitted rusty front coil springs worth saving
Re: Are original pitted rusty front coil springs worth saving
40 years. That means they were put in the basement when new. How did they get pitted? If it is only surface rust, of course they are worth saving. I would think even with pitting they are worth saving.- Top
I think you can find the right springs but have to know what to look for. I think many people just order heavy duty,BB or AC springs without checking what spring realy came on the car. On needs to find the correct # of coils,dia. & hight of the spring. Also just changing the front & not the rear on C-2 & 3'S will make the Corvette set funny. You need to change front & rear.Ralph,
Springs (coil or leaf) are very sensitive to wire diameter or leaf thickness -- thus any corrosion much beyond surface rust can result in a decreased ride height, and potential cracking due to the corrosion. As to whether any of that is actually a factor with these springs would require a metallurgical test that is probably beyond most of us. If I really wanted to use those springs I would install them without doing much to them, check the ride height after using them for a while -- drive the car a bit and see how they "settle out." If that was OK then refinishing would be my next step. A lot of work? Sure. That is the price of an accurate restoration. Of course if one feels lucky, as Harry Callahan said ….
BTW: I have no direct experience with reproduction springs, but I have seen some unfortunate results on the show field. I have been campaigning (so far unsuccessfully) for over a decade to get a line item on the score sheets for ride height. Maybe about the time I get that the aftermarket suppliers will have solved their ride height issues. Then again I might pass first or Hell might freeze over.
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Ralph,
Save them, imagine what they would look like if they were compressed for 40 years and out in the WX.
I had the same and sent them out to be powder coated.
DOM- Top
How about a picture? A close-up of a typical section of a surface. It should be in focus as well.
This will get you a lot more informed feedback.Steve L
73 coupe since new
Capital Corvette Club
Ottawa, Canada- Top
Here you go Steve. Since Mark and I are Ralph's designated picture posters -- Ralph is photographically challenged.
rusty springs.jpgTerry- Top
- Top
Ralph,
I would glass bead, paint and use them. I have a set of 1968 BB springs from a 400hp car and they may be the same part #3931823, (I will check).- Top
