What do you use to keep the unprotected metal from rusting?
So you strip the paint off your Engine Stamp pad...
Re: So you strip the paint off your Engine Stamp pad...
Original pad surfaces develop a nice patina but don't necessarily rust. Most of the heavily rusted surfaces you see have been manipulated to hide something. This patina I am talking about is always present in original pad surfaces. Strip the paint and clean it that's all.- Top
- Top
A drop of any kind of oil will work it gives it that gray iron look.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
I am with Gerard. Pre-Lube 6 is one of the finest bare metal protectors of corrosion there is. Just put a little on your finger and rub it on and then wipe off the excees."SOLID LIFTERS MATTER"- Top
T9 Boeshield - works very well
http://boeshield.com/- Top
Kurt, I have been using T9 Boeshield for as long as I can remember. First time I ever saw someone mention the product here. Boeing aircraft productT9 Boeshield - works very well
Great on locks. I use it on my low mileage bicycle chain too. There is always a can of T9 in my trailer. If I have trouble with the electrical plug going into the tow vehicle I spray T9 all over the contacts and it never fails me.
On the fuel injection restorations I use it on the hi-pressure pumps.
I will have to try Pre Lube 6 also. Thanks, JD- Top
