I picked up a pair of License Plate Frames that the owner indicated that they were from his 1961 Corvette that he had never installed and had been laying around in his shop. They have a paper tag with the same patient number that is stamped on another pair that I also have. The frames are in plastic bags that are very thin like the plastic on dry cleaned cloths bags. Interested in hearing if older plates came this way with tags and if this is correct.
1961 License Plate Frames
Re: 1961 License Plate Frames
Steve------I picked up a pair of License Plate Frames that the owner indicated that they were from his 1961 Corvette that he had never installed and had been laying around in his shop. They have a paper tag with the same patient number that is stamped on another pair that I also have. The frames are in plastic bags that are very thin like the plastic on dry cleaned cloths bags. Interested in hearing if older plates came this way with tags and if this is correct.
I can tell you this much: the original license plate frame supplied with my 1969 were supplied in thin plastic "bags". Whether they were doing that in 1961 I do not know. However, 1961 Corvettes did not use the same license plate frames as 63-82.In Appreciation of John Hinckley- Top
