The driver side front corner of my hood is about 1/8" higher than the front clip body surround. It is about the same from that point to the center of the hood, where it then works its way flush at the passenger side. There is one shim at the passenger hinge, and no shims at the driver hinge. I was searching the archives for a way to correct this issue, but didn't find a clear answer to the problem. Is it possible to adjust the nose upward about 1/8" so it can be flush with the hood? I already tried loosening the top bolt on both the nose & headlight support rods and pulled up on the metal nose support brace as I tightened the bolts, but nothing changed. The driver headlight support rod has a bend in it while the passenger support rod is straight. I am sure that there was a repair to the front end at some point in its past (replacement parking light panels, at least one inner fender, and ??)... perhaps the bent rod was how they "bubba" adjusted the nose. Should I remove the bent rod, straighten it, and then reinstall it? Will that raise the front clip surround, or will the hood & inner fender move up, too? Will the headlight bucket move with the nose, or will it stay in place creating a misalignment with the body? I would like to correct this minor issue if possible, but I certainly don't want to make things worse!
I would also like to take this opportunity to thank all who have served our great country!!
Enjoy your Memorial Day,
Roger (50141)
Roger (50141)
