54 harmonic balancer - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Can the balancer be removed with all the oil still in the pan? I have a leak there as the oil pools on the lip under the balancer. I can see its not coming from the balancer seal and I removed the pan and appliaed sealer to the bolts to the timing cover from the inside. That leaves the very bottom of the timing cover but I cant tell for sure. If I can remove the balancer with the oil in maybe I can verify that the cover is leaking. Its not the little freeze plug. Can the timing cover come off with the water pump in place? Thanks as always.
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 harmonic balancer
    The balancer can come off with the pan on
    Double check the little freeze plug - mine leaked there
    you may have the replace the front seal - lube the seal and balancer when you re-install
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
