Delco Distributor cap patent pending R - NCRS Discussion Boards
  • Ken A.
    • July 31, 1986
    • 929
    #31
    Re: Delco Distributor cap patent pending R
    AHA!​ maybe I am on to something????
    You guys are getting close-think of the system, not the components, and think of EMISSIONS.
    • Dick W.
      • 10483
      #32
      That is what I am thinking, a small step toward reducing emissions? WTFDIK?
      Dick Whittington
      • William C.
        • May 31, 1975
        • 6037
        #33
        Resistance internal to the wiring started well before the "R" was added to the cap.
        Bill Clupper #618
        • Dick W.
          • 10483
          #34
          Well that blew that theory.
          Dick Whittington
          • Ken A.
            • July 31, 1986
            • 929
            #35
            You were almost there, but you gave up too easily. Think system/emissions.
            • William C.
              • May 31, 1975
              • 6037
              #36
              After thinking through the events of the era when all this ocurred, I believe the "R" was added to indicate Registered patent on the paqrt. GM/delco were always fighting the aftermarket sources who made knockoffs of the cap, despite it being illegal to do so, and the lack of a "R" was one of the issues the Gov't used to explain why they were not defending the patent. The second change to add the part number is likely due to two things, if as I recall it happened around 1975, that is when GM was moving to HEI, so the demand for the D-308 style cap was going to H--- in a handbasket, and also new technologies in Phenolic molding were becoming available. The new technology required new tooling and by this time it was a service item only so why not build the new tooling to include the actual part number of the item? I wasn't there, but where I worked we had a MAJOR phenolic molding operation to make Fuseblocks, right up to the changeover to the "Autofuse" One of the folks I worked with was the molding engineer in that area, and I recall some major technology (Process related) changes in that era, all requiring new tooling.
              Bill Clupper #618
              • William C.
                • May 31, 1975
                • 6037
                #37
                GM NEVER used an external resistor in the secondary ignition system. GM owned the patent (via Packard Electric Div) on resistance wires which were MUCH more effective than external resistors for radio noise suppression, the ONLY reason to have resistance in a secondary ignition circuit.
                Bill Clupper #618
                • William C.
                  • May 31, 1975
                  • 6037
                  #38
                  Emissions was only a pipe dream when these caps were used, at least in relative terms as to what came later. Remember GM went to HEI across the board in 1975 with only a few exception.
                  Bill Clupper #618
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    #39
                    Bill
                    Do you have anything in writing to prove your belief that the "R" is an indicator for a registered patent or trade mark.
                    • William C.
                      • May 31, 1975
                      • 6037
                      #40
                      Sorry I don't since my retirement and the disbandment of the old ACG group via the Delphi spinoff and subsequent bankruptcy of Delphi. At this point, God only knows how much of that documentation may even exist. My old outfit Packard Electric, went from a "keep everything" approach to a "Throw everything out" approach in the 2000-2010 era under Delphi. All I know from my working in Joint group meetings in the old ACG (Allied Component Groups Delco Remy, Saginaw Steering, AC, Packard Electric, Delco Products Delco Radio, Later Delco Electronics) is that the late 60's there was a push to show patent and trademark protection and the "R" was commonly used to signify "Registered Trademark" within the GM Component Groups.
                      Bill Clupper #618
                      • G A.
                        • February 18, 2010
                        • 229
                        #41
                        Bill
                        Has anyone read this?
                        http://www.uspatent.com/resources/en...epreneurs-faq/
                          • 15573
                          #42
                          Originally posted by Ralph Spears (8296)
                          What is the R for after Patent Pending
                          Some photos with no explanation from Ralph.
