1968 Corvette Transistor Ignition - NCRS Discussion Boards
  • Craig S.
    • February 19, 2010
    • 39
    I recently purchased a 1968 Tri Power Convertible from the original owner. It had not been run for an extended time. It has the transistor ignition distributer . Can anyone tell me which wires go to the coil. I think I remember reading somewhere that transistor ignition is opposite from the points distributor for the wire connections. There is a shielded wire, whitish gray, and a black wire and the wire from the capacitor on the coil bracket. Does the shielded wire connect to the positive or negative side of the coil? This old girl is about back from the dead, but I want to make sure the coil connections are correct before I hit the key. Any help is deeply appreciated.
  • Craig S.
    • February 19, 2010
    • 39
    Re: 1968 Corvette Transistor Ignition
    Sorry guys! Found the answer to my question a few days ago on another post. Been too busy to be on line each day. Thanks again.
