1960 Door Glass; Install track w/ seal - NCRS Discussion Boards
  • Terry B.
    • December 1, 1988
    • 111
    SORRY, I originally posted this on the wrong forum.
  • Dan B.
    • July 13, 2011
    • 545
    Re: 1960 Door Glass; Install track w/ seal
    Try starting just one end at an angle with a rubber mallet. Once the track opens a bit, the rest will tap in place. Dan
    • Terry B.
      • December 1, 1988
      • 111
      That is how I got the other glass assembled. It didn't work with this side. I tried pushing one end on with the clamp and tapping with my mallet but was not successful. The other glass had a very slight bevel on the bottom edge, otherwise I see no differences.
      • Donald H.
        • November 2, 2009
        • 2580
        Are you sure the bottom track has not been crushed a little? I had lots of trouble getting my 60 side window replacement glass into the stainless surround, but don't recall having a big problem getting the bottom track with the drip rubber on. I would suggest trying to find a thin piece of hardwood, e.g. oak, maple slightly thicker than the glass and drive it into the groove in the track (without the rubber trough in) to slightly spread out the track.
        I would do that before I tried to mess to much with the glass. I just had to order another windshield, I crack the first one trying to get the assembly together
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
