I'm doing my door weatherstrip this weekend on my 60. I did the trunk and deck lids using Weldwood contact cement. For the Weldwood, I brushed cement on both the body surface and the weatherstrip, let it dry to tacky then stuck together. Seem to work very good.
I just got a quart of Al Knoch's cement and it more yellow that the Weldwood which looks tan to me. So I though I would try the Knoch cement on my doors. I used the same technique, coated both surfaces and let it tack dry, but I does not seem to stick very well. So I read the instructions on the can
, Knoch's instruction seem to say coat both surfaces and then stick together immediately.
If you have used the Al Knoch cement on your weatherstrip, what application technique did you use, and did it stick good.
By the way, I did pre clean both the weatherstrip and door surfaces with was and grease cleaner before I started.
Don Harris
, Knoch's instruction seem to say coat both surfaces and then stick together immediately. If you have used the Al Knoch cement on your weatherstrip, what application technique did you use, and did it stick good.
Don Harris
