Finished the restoration. Took it for setup of timing and FI (1964 L-84). Had to leave the shop during setup which was completed when I returned.
They told me they plugged the vacumm hose because "I didn't need the vacuum advance". The next day I took it out for its first drive. Once I had stopped for a couple of traffic lights, parked and restarted twice, the temperature rose to near the highest mark. Driving it for a mile or two without stopping brought the temp down but never to the 180 deg mark. At one traffic light it loaded up and almost stalled.
The FI unit is freshly restored by one of our experts with his 180 deg thermostat installed. The same for the distributor. The water pump is freshly rebuilt. The fan clutch is a fresh rebuild. The radiator and overflow are new from DeWitt with shroud in place. Hoses and fan belt are new. No water leaks detected. The radiator cap is new at 13# and it has not boiled over but the rough running at lights is enough to convince me that something needs to be fixed. The only thing I can think of is the vacuum advance being disconnected and causing a too rich mixture at idle.
Am I on the right track or missing something?
Thanks in advance.
Doug
Thanks in advance.
Doug
