C1 Mounting Rear Bumpers 58 59 60 - NCRS Discussion Boards
  • Richard H.
    • March 1, 1985
    • 241
    Installed the rear bumpers for the first time. Now, in mounting the vertical bumpers the bolting pattern is clear and simple. However, with the main bumpers mounted, it is a challenge to actually bolt the verticals to the bumpers due to the restriction of space. Can't see the bolt and seems impossible to get one's hand or a tool in there to secure it. Is the proper procedure to mount the verticals to the bumper and bracket first and then mount the entire assembly?
  • James O.
    • November 1, 1985
    • 160
    Re: C1 Mounting Rear Bumpers 58 59 60
    yes . that's correct. also, don't forget to pre-attach the lower brackets that go to the rear crossmember
    • Bob M.
      • March 1, 2004
      • 66
      Make sure the bumperette bolt is going the right way in the bumper if you plan on having your car judged.
