Fuse puller picture needed - NCRS Discussion Boards
  • Rod M.
    • July 30, 2008
    • 36
    Just purchased a 93 C4 and found out that it was missing the fuse puller that is mounted on the inside of the fuse panel. I need apicture of this puller to insure that I get the right part. If anyone has a picture please send it rodemcleod@gmail.com thanks for the help.
  • Pat M.
    • April 1, 2006
    • 1575
    Re: Fuse puller picture needed
    Rod, here's what my 96 puller looks like. It's got two little opposite facing "tooths" on the pulling end. I don't know if it's the same as 93.
    • Bill H.
      • August 8, 2011
      • 439
      pat's 96 looks different than my 92. The puller is labeled fuse on one side and breaker on the other.
      • Pat M.
        • April 1, 2006
        • 1575
        Bill's correct. Mine is not labeled and looks shorter.
        • Rod M.
          • July 30, 2008
          • 36
          Thanks for the picture. I have been told that there were at least two different pullers in the C4 series. No one knows for sure which one is right for the 93. Since my car was built in late 92 I am going with the picture of the one from the 92. Thanks for sending the picture.
          • Rod M.
            • July 30, 2008
            • 36
            Bill, what is the length of your 92 puller?
            • Tom H.
              • December 1, 1993
              • 3440
              Here's what it should look like ! Just happen to have one in my desk drawer !!!
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Bill H.
                • August 8, 2011
                • 439
                Tom, That's the "newer" style but I have no idea what model year that change took place in.
                Rod, It's easy to tell which you have. Look at the holder in the fuse door. My puller is roughly 3 1/2 in.
                There's a slot in the tabs on the door for the black, metal tang to fit thru.
                The picture quality isn't that good but....
                • Rod M.
                  • July 30, 2008
                  • 36
                  Bill, Thanks for the picture of the panel with the fuse puller. My panel is the exactly same. Now I know which puller to get. Next I need to find an orginal A.I.R duct filter.
                  • Pat F.
                    • April 1, 1981
                    • 852
                    Rod, hope this helps.
                    My 1995 Corvette was built on August 4, 1994, second day of production.
                    PAT, Central New Jersey and Florida Chapters
                    • Rod M.
                      • July 30, 2008
                      • 36
                      Thanks Charlie, Looks like the puller is different from 94 thru 96. The 93 puller is much longer - 3.3/4
                      • Jim S.
                        • November 30, 1999
                        • 73
                        My '96 is also missing a fuse puller and based on replies to this thread I know which one to get - but where do I find one?
                        • Pat F.
                          • April 1, 1981
                          • 852
                          Jim, perhaps Tom Hendricks can tell us if this fuse puller was used any other GM Product.
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            Hey Jim ! Tell ya what. I will send you the one from my desk drawer. The one in my picture. Just PM me your address. If you ever stumble onto another one somewhere, just send it back ! Be glad to let you have this one. Tom
                            Tom Hendricks
                            • Pat F.
                              • April 1, 1981
                              • 852
                              Tom, the desk drawer comes through again.
                              I was thinking that maybe these fuse pullers were on other era GM products. Just a thought.
