1971 Emission Canister Location - NCRS Discussion Boards
  • Craig H.
    • December 17, 2010
    • 59
    Hi
    I need to fit my Vacuum canister and emission canister to drivers side inner guard but need some measurements please.
    Could someone please give me the measurement from the bottom emission canister bracket bolt centers to the bottom of the fiberglass inner guard. I should be able to space it out from there.
    The bolt holes I have are all wrong as it has been incorrectly repaired at some stage.
    regards
    Craig
    • 3415
    Re: 1971 Emission Canister Location
    Hi Craig,
    On my 71 that dimension is 2 3/8".
    The dimension from the centerline of the outer bolt hole to the edge on the apron reinforcement is 3" That's measuring straight towards the fender from the hole.
    • Craig H.
      • December 17, 2010
      • 59
      Thanks Alan
      Exactly what I needed, you preempted the other measurement as well :-)
      Regards
      Craig
