Manual window regulator reinstallation - NCRS Discussion Boards
  • Brian G.
    • May 31, 2003
    • 2
    I removed my 1959 manual window regulator that was stripped (crank portion) last year before storing the car for the winter. I followed the proper instructions but still had trouble getting it out because of the post and guide assembly inside the door. I purchase a pair of reproduction regulators and am now trying to put in the driver side regulator. All the written instructions say to just put it back in through the large access hole. Can someone share the trick to getting it past the post and guide assembly inside the door or do I have to somehow remove more innards? There is very little tolerance to move the regulator inside the door. Thanks
    Brian
  • Philip P.
    • February 28, 2011
    • 558
    Re: Manual window regulator reinstallation
    I got the information below from the Corvette Restoration and Preservation List, I have not tried this as of yet. May help
    Phil
    In order to remove the regulator, you must remove the steel brace that
    attaches to the bottom of the door post. The post does not need to be
    removed but the brace must be to get the regulator out. with this brace in
    place there is no way to get the unit past this brace. It just bolts in
    place and is easily removed. This same part makes the in/out adjustment at
    the top of the window, so you may have to re-adjust this after you replace
    it. The bottom bolt is in a slot that allows the brace to slide back and
    forth to allow the adjustment.
    • Donald H.
      • November 2, 2009
      • 2580
      i just put my doors back together on my 60. What I found is that you have to crank the regulator assembly one way or the other to get it past the fixed brace inside the door. The regulator assembly and the large toothed gear need to be aligned just right to get it through the space between that fixed brace and the inner door skin.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Brian G.
        • May 31, 2003
        • 2
        Thank you both very much. I am sorry I have not responded but my membership expired just after I posted, and despite immediately re-subscribing, have not been able to access the forum until now. Thanks kindly. I will try again with this knowlege.
