Speed warning wiring - NCRS Discussion Boards
  • John M.
    • June 27, 2010
    • 179
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Speed warning wiring
    John,
    Check out pages G445 and G447 in the options section in the back of the assembly manual.
    JR
    • John M.
      • June 27, 2010
      • 179
      Joe I saw those but it does not show the orange wire with the 2 connectors is the Bat Fuse one connection? if yes where does the other connector go?
        Originally posted by John Mikelaitis (51914)
        John -
        The wire routing is shown in your Assembly Manual in section U15, sheet A1. The end of the orange wire at the fuse block has two connectors - the female one plugs onto the male spade in the cavity in the fuse block (it's the "BAT" cavity above where it says "Power Windows" on the fuse block, not "BAT FUSED"), and the other male connector becomes a spare if you need to plug something else into battery power (you'll see it in View "A", taped to the orange wire).
        It's not shown in the factory wiring diagram, as it's an option; it IS shown on Doc Rebuild's '67 wiring diagram.
        • John M.
          • June 27, 2010
          • 179
          John thanks, I didn't take this car apart so sometimes it becomes painful trying to understand the assembly manual.
