Can someone help me with the torpedo lights on a 67 air condition roadster? Where does the double gray wire get pluged in at? The wiring schm. Shows all the grays tied into each other but i can't find where the connections goes. Sorry for the write using the phone. Thanks
Torpedo light wiring
Re: Torpedo light wiring
John -Can someone help me with the torpedo lights on a 67 air condition roadster? Where does the double gray wire get pluged in at? The wiring schm. Shows all the grays tied into each other but i can't find where the connections goes. Sorry for the write using the phone. Thanks
That separate "torpedo light" wire plugs into the fuse block, in the cavity marked "ACC. LAMPS", as shown in your Assembly Manual, section C60, sheet E8.- Top
Tom -
Yes, they are - that's why there are the two additional "torpedo" lamps on an A/C car, which shine upwards when they're installed correctly (they are different left and right hand parts); correct installation is shown in View "A" on the A.I.M. sheet I referenced in my earlier post.- Top
Tom I reviewed sheet "A" and i'm still confused. They look like they plug straight in like the center one. I'm sure you are correct it only makes sense they would light the upper knobs however it also seems like they will hit the AC ducting.- Top
