Can someone confirm that the bolts in the photo below are original 55-57 Corvette fuel pump bolts. The 9/16" hex head bolts are 3/8"-16 with an effective length of 1.0" and a threaded length that measures about 0.65". The head marking is "TR" with 3 radial line segments spaced at 120 degrees. I removed the bolts from a 56 or 57 Chevy engine that was just sitting on the ground in a junkyard in Lancaster, MA, back in May 1991. The fuel pump was stamped "4262".
Dave
Dave
