63 jack board bezel question - NCRS Discussion Boards
    • 6940
    I was reading the JM on 63 jack board bezel, My 63 had a older pitted chrome bezel so I replaced it with a chrome one, JM stated it should be natural or zinc. Is the another 63 only part or were there chrome ones also? thanks Ed
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 63 jack board bezel question
    Ed, another 63 only part. Take your old chrome one, remove the remaining chrome then polish the natural metal.
      • 6940
      Thanks Harry, I through out the old one, I'll just dip the new one in battery acid and see if the chrome can be removed that way?
      • Tom A.
        NCRS Body & Paint Advisor
        • May 31, 1986
        • 138
        Ed, battery (sulfuric) acid will strip your chrome but you might want to dilute it about 8 to 1 with water (8 parts water 1 acid) so it doesn't eat it to quickly.
          • 6940
          Tom, Thanks for the advice.
          • Harry S.
            • July 31, 2002
            • 5258
            I used a sanding wheel on my small Dremel. When the chrome was gone I sanded with 400 to 12000 wet sand paper.
              • 6940
              Harry, I has some luck removing other types of plating with battery acid, Chrome? I will give it a try with acid. It may not work, Then It will be your way.
              • John D.
                • December 1, 1979
                • 5507
                A plating shop will strip the chrome for you. Probably do it for a buck or two.
                  • 6940
                  John, I found out today the bezel is not chrome, Its polished stainless steel. so I guess I still need another one, Hopefully it will not be the same.
                  • Tom A.
                    • May 31, 1986
                    • 138
                    A bezel with the correct finish is available and not very expensive.
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      Where?is it available?
                      • Tom A.
                        • May 31, 1986
                        • 138
                        I'm sorry I checked the vendor I last purchased one from and they no longer carry the 63 only bezel. It's getting harder and harder to get the right stuff.
                        • John D.
                          • December 1, 1979
                          • 5507
                          The bezel in my 63 was rusty as I recall. Turns out it was in fact bare metal. But I ruined the originality of it as had it zincad plated.
                          Makes one wonder why in fact an piece of interior trim was bare metal. JD
