Refinishing 1968 Shift Plate - NCRS Discussion Boards
  • Bob S.
    • May 31, 1986
    • 254
    I'm going to be refinishing my '68 shift plate. Any suggestions would be greatly appreciated.
    Way back, I had great success in refinishing the Faux Vents on the hood of my '63, using pin stripping tape and krylon paint. I'm thinking of going the same way here, unless, of course, there are better ways. I'm especially concerned with the raised lettering. This, I have no experience with.
    Also, why don't they make a replacement for the '68?
    Thanks in advance,
    Bob
    (9944)
  • Russ S.
    • April 30, 1982
    • 2161
    Re: Refinishing 1968 Shift Plate
    Bob, On the lettering I would just paint over them and let dry for about ten minutes then use a paper towel or cloth lightly dipped in lacquer thinner and carefully wipe off the top of the letters.
      • 11608
      SEM Trim Black is a better color - and a better paint.
      I've used the blue masking tape and an X-Acto knife to mask the chrome edges, and you can wipe off the paint from the letters as Russ describes.
      Patrick
      • Bob S.
        • May 31, 1986
        • 254
        Thanks, Russ.
        • Michael D.
          • June 30, 1996
          • 536
          I used the old 5-ball Krylon semi-flat black. These days you have to purchase it from an industrial coatings outlet.
          • Bob S.
            • May 31, 1986
            • 254
            Patrick
            Is the Trim Black a Flat Black?
            • Bob S.
              • May 31, 1986
              • 254
              Thanks, Russ
              • Bob S.
                • May 31, 1986
                • 254
                Thank you!
                • Bob S.
                  • May 31, 1986
                  • 254
                  One last question....What is recommended as the best paint remover?
                  BD
                  (9944)
                  • Douglas C.
                    • August 31, 1990
                    • 379
                    Krylon # 1613 is a dead-on match for GM interior pieces. And I have always scraped the excess paint off the letters with a razor blade, works for me.
                    • Michael D.
                      • June 30, 1996
                      • 536
                      Originally posted by Bob De Simone (9944)
                      ...One last question....What is recommended as the best paint remover?...
                      The trim plate is metal, so you can use any of the commercial stuff you would not otherwise use on fiberglass. Zip-Strip works but takes it's time doing it. Brake fluid will eat paint. Some folks say Easy Off Oven Cleaner will do it.
                      • Don L.
                        • August 31, 2005
                        • 1005
                        I've used Krylon #1613 and I've used SEM Trim Black. As Patrick suggests, the Trim Black IS the better material. Not as easy to find, you'll likely have to go to an automotive paint store to get it. You'll pay more too, but IMHO, it's well worth the premium. When I re-did my shift plate, I believe I masked the perimeter chrome and wiped the rest. I used a cut off wooden coffee stir-stick to wipe. Found the paper towel too difficult to control. Apply the paint sparingly so as not to fill the graining with paint.
                        This is not a tough job. Have confidence and take your time. You'll get good results.
                        Don Lowe
                        NCRS #44382
                        Carolinas Chapter
                        • Mike B.
                          • April 30, 2001
                          • 8
                          As others have suggested, I masked off the chrome boarder and the crossed flag emblem. For the raised letters I put a little (like a film) of lithium grease on the tip of a finger and then touched the tops of the letters right before painting so the paint did not stick.
                          At the time I thought chapstick or carmex might work as well or better but I did not have any around.
                          • Bob S.
                            • May 31, 1986
                            • 254
                            Thanks Michael!
                              • 11608
                              Nope, stain black.
                              It's dead nuts on for the original color.
