I own a late May built 1967 427 435hp California delivered car which I purchased from the original owner. I have known this car since 1972 and there is no doubt in my mind it has the original engine. It has not run since parked in 1971. The pad is stamped is stamped TI0I19JA. I have the original build sheet for this car which also has the engine number listed the same as the stamping. The pad reflects the correct VIN. Can anyone interpret the stamping for me? Thanks in advance.
1967 427 435 hp Engine Assembly Stamping
Re: 1967 427 435 hp Engine Assembly Stamping
You've got one digit too many between the 'T' and the 'JA', there should be only four characters.- Top
Is the extra "1" a typing error? Should it be "TI0I9JA"?
"T" = Tonowanda, NY
"I0" = October
"I9" = 19th of the month
"JA" = 427 eng. A.I.R. Special High performance and Tri. Carb.
The October 19, 1966, engine seems quite early for a late May 1967 car but it is possible. The big difference in dates in more common with the big block engines.
Has a NCRS judge told you that your engine does not meet the ridiculous "6 month rule"? Your documentation seems to indicate that it's an original engine.
Dave- Top
David and Michael thank you for your responses. I looked at the build sheet again and it reflects as David says, T1019JA. Interestingly, the build sheet uses the number "1" where if I remember correctly, the stamping uses the capital letter "I". This weekend I will re-examine the pad and post my finding. I agree, an October built engine for a May car seems early. Thanks again.
Charles (Rick) Gower- Top
Two 390 California cars with K-19 smog I know well are
NUMBERS;
TRIM TAG
I27 (April 27)
67 467 S7630
STD 983AA Pt
With Engine:
Cast date C 21 7 (March 21, 67)
Stamp T0404IM 7S117322
“IM”= 67 Corvette, 427/390hp, manual trans with K-19 A.I.R. Smog
NCRS SHIPPING DATA:EDDIE HOOPER CHEVROLET, GARDEN GROVE, CALIFORNIA
and my old PG AIR CONDITIONED POWERGLIDE CONVERT
67 # 20689, silver/ blk vinyl, vinyl hard top, black soft top, TRIM TAG :
K12= June 12, 1967
67-467 BODY S6665
TR std
Paint 986AA
tank sticker Zone 19 dealer 017
Engine T0515IR 7120689
435 cars may be different. I would go ask Al G. as he has a huge library to compare data to.Over 80 Corvettes of fun ! Love Rochester Fuel Injection 57-65 cars. Love CORVETTE RACE CARS
Co-Founder REGISTRY OF CORVETTE RACE CARS.COM- Top
What is the block casting date and some of the other date codes on other engine parts. As James suggested the stamp on the pad may be mis-stamped. Maybe it should have been "01" for January instead of "10" for October.
I assume that the number ones on the stamping are like the letter "I" which is normal for Chevrolet.
Dave- Top
Hi John,
Yes it is Copy 7. I have the car stored across town and tomorrow will try to get over and check the block casting date and post. Unfortunately the 391 heads were changed prior to the car being parked and are dated around 1968 but are still 391. Any other dates I should be looking for? I do have the Protect-O-Plate. Interestingly the Copy 7 shows a date received as 04-17-67 with an Exp. Date of Prod. as 04-19-67. However the block which shows the carburetor code, engine number, etc shows the date produced as 5-25-67.
Thanks John, Jim, Michael and David. I appreciate your comments.
Rick- Top
Dave and All,The numbers and dates are as follows:Block (351) casting date: J 12 6Stamp pad: TI0I9JA 71194XXCarbs: rear: 3659 713 center: 3660 721 front: 3659 743Starter: 1107365 7 A 8Distributor: 1111258 6 J 12Smog pump: stamping in aluminum 10171P on cast base: D5 283 3696182 (???hard to read)Alternator: 1100696 42A 7 E 11Thanks again,Rick- Top
block: "J 12 6" (Oct. 12, 1966)
carbs: "713" (1967, Jan. 3rd week)
"721" (1967, Feb. 1st week)
"743" (1967, Apr. 3rd week)
starter: "7 A 8" (1967, Jan. 8th)
dist.: "6 J 12" (1966, Sept. 12th)
smog: "6 J 12" (1966, Sept. 12th)
alt: "7 E 11" (1967, May 11th)
The letter "I" is usually omitted in stamped date codes (M = Dec.)
Casting dates include the letter "I" (L = Dec.)
What's the problem? They did not make many of these engines in 1967. As far as I know all the components (identified by part numbers) that you listed are correct.
Your engine was assembled Oct. 19, 1966 in Tonowanda and apparently sat around for awhile with other 427's until you car was built in May 1967 and all the other components were installed on the engine.
Dave- Top
