1957 dimmer switch - NCRS Discussion Boards
1957 dimmer switch
  • Theodore K.
    • December 1, 1985
    • 214
    1957 dimmer switch
    The 1957 schematic is not clear on this point. Does the dimmer switch toggle the headlight feed wire between low and high beam or does it add the high to the low and have both on?
    Ted
  • Dan D.
    • November 5, 2008
    • 1323
    Re: 1957 dimmer switch
    Ted, toggles between low & high beam. Dimmer switch is SPDT. Dan
    • Theodore K.
      • December 1, 1985
      • 214
      Thanks Dan.. that is what I thought. Just wanted to be sure. I posted another thread concerning the current division makeup and schematic for the switch. If you have any comments, sure would appreciate it.
      Ted
