Lets assume I do not have a leak.
I just recently installed a new condenser, shaft seal and expansion valve in my 67 small block car with factory AC. I triple evacuated the system and to verify no leaks under vacuum, I did a drop test over 24 hours and the system pressure did not rise above 500 microns.
Prior to adding refrigerant via a Dial-a -Charge I pre-measured the volume of R-12 that would be lost in the hoses and manifold gauges (2.5 ounces). I added 3 lbs 3 ounces to dial-a-charge cylinder and transferred the charge to the car. I have bubbles in the sight glass. Before I add additional refrigerant I was wondering if others have to say about how many additional ounces I should add and what is the maximum charge (liquid volume) that can safety be added to a AC system?
The system is cooling in the cabin, but I did not take any measurements as the ambient temperature is 98 degrees and my IR gun showed 220 degrees on the upper radiator hose.
Thanks in advance for your responses---Mark
