67 paint the way the General did it - NCRS Discussion Boards
  • Daniel E.
    • April 30, 2005
    • 145
    Re: 67 paint the way the General did it
    A few more....
    Body colored dash tab. Elkhart blue with teal interior. Note overspray on the dash pad
    Passenger side hood hinge overspray. Also note the white paper stickers on the inner fender (these appear to have been in place during black out) and the unpainted area where a shim was installed between the core support and inner fender.
    Original Teal stinger on Elkhart blue body
    Grease applied to the grommet of the glove box support rod
    • Wayne W.
      • April 30, 1982
      • 3605
      The picture of the header bar seems to show it unpainted, and maybe zinc chromate, which would indicate an AOS body, however it has a BB hood with stinger. The radiator support shows black though. Is it an AOS body? Has the header bar just lost what black it should have? Could it be the elusive AOS BB?
      https://www.forums.ncrs.org/attachme...0&d=1341008927
      • George W.
        • July 31, 1998
        • 322
        #18
        It is a St. Louis body; look at post #1 at rivets in the door.
        Dr. George
        • Scott S.
          • September 11, 2009
          • 1961
          #19
          Daniel,
          Thanks very much for the pictures.
          I have read conflicting information about the headlight bucket front bezel screws, it would be good to find out what a low mileage survivor has in this area. I thought it should have two black screws at the bottom of each bezel and a cad or zinc screw on each side (UPC 12-A2, items 17 and 19). Others say it should be opposite, cad-zinc at the bottom location and black phosphate at the sides. Do you have pictures of the headlight buckets/bezels showing these screws, or do you know which screws this car had, at which locations?
          • Scott S.
            • 1961
            #20
            Originally posted by Daniel Edmond (43962)
            Here are some additional photos. Sorry, I don't have any of the hood.
            Inside of passenger side front fender. There doesn't appear to be any body color overspray but there is red primer
            [ATTACH=CONFIG]40392[/ATTACH]
            [ATTACH=CONFIG]40393[/ATTACH]
            There appears to be red primer just under the rain gutter of the hood-surround, as well as the back side of the fender vents (and some on the overlap of the RH inner fender just forward of the vent). What is the factory process that results in red primer getting in these areas? Was the entire engine bay from about the mid-body line down originally sprayed with red primer at the same time as the exterior body?
            • Wayne W.
              • April 30, 1982
              • 3605
              #21
              Yep, didn't catch that. Doors can be changed, but in this case not.
              • Wayne W.
                • April 30, 1982
                • 3605
                #22
                The entire body was assembled and then primed. From this example it is evident that they made at least some attempt to get some primer on the inner fender surfaces, thus the primer under the gutter, and some on the inside of the fender. Not much, but some.
                • Tom A.
                  NCRS Body & Paint Advisor
                  • May 31, 1986
                  • 138
                  #23
                  Great pictures Daniel. Thanks for posting. We need to see a lot more like this. It really helps to understand what original appearance means.
                  • Daniel E.
                    • April 30, 2005
                    • 145
                    #24
                    Wayne,
                    It is a St. Louis body (S8158). The header doesn't have any zinc chromate (green) on it.
                    Daniel
                    • Daniel E.
                      • April 30, 2005
                      • 145
                      #25
                      Scott,
                      I'm going to add to the confusion. All of the screws to attach the headlight bezels appear to be cad-zinc. The low beam lamps were replaced so there is a possiblity the screws were lost/replaced during this, but I doubt that all of them would have been.
                      Daniel
                      • Daniel E.
                        • April 30, 2005
                        • 145
                        #26
                        Pictures with the exhaust panel removed. It was obviously in place before any primer/paint was applied.
                        • Scott S.
                          • 1961
                          #27
                          Scott,
                          Daniel
                          Daniel,
                          Thanks for checking. There may be another way to skin this cat. The 67 AIM (12-A2) drawing shows that item 17 Screw GM 9420683 is used to attach the headlight bezel at the bottom (although item 19 Screw, GM 9420684 is shown going into the side of the bezel, but called out in the itemized list as "Screw Bezel Asm. Lower", adding to the confusion).
                          The item 17 Screw (GM 9420683) was ALSO used to attach the Inner and Outer Pivot Assemblies (items 15 & 16). There should be 16 of these screws between the four Pivot Assemblies, and on a low mileage car, chances should be good that most if not all of them are original. Whatever these screws are (flat head Phillips, Cad or black?) that secure the inner and outer Pivot Assemblies, it should be the same screw and finish originally used at the bottom location of the headlamp bucket bezel.
                          • Scott S.
                            • 1961
                            #28
                            [ATTACH=CONFIG]40404[/ATTACH][ATTACH=CONFIG]40405[/ATTACH]
                            Daniel,
                            These are great pictures, thanks again for posting. I have read about the procedure that resulted in the paint lines you show, but had never seen a "survivor" example with the rear valance removed.
                            Another procedure or process question. It's interesting that there's just black glass, no red primer on the main rear body where the rear valance shielded it while temporarily installed during body paint. Does this mean (seems to) that the lower rear valance, attached with two bolts before the red primer was ever applied, was apparently secured tightly enough that little or no red primer overspray would get through the open bolt holes or behind the top edge of the rear valance?
                            I had thought the rear valance was only attached loosely, which would allow for some red primer and body paint overspray behind the rear valance.
                            • Michael G.
                              • November 12, 2008
                              • 2155
                              #29
                              Daniel, nice pics, thanks for posting. If you could post one of the radiator support, (taken looking up at one of the bottom of the valence) that would be great.
                              • Wayne W.
                                • April 30, 1982
                                • 3605
                                #30
                                Scott,
                                Daniel
                                These self tapping flat headed, beveled, Phillips screws were bright plated. With what (cad,zinc, etc.) I don't know.
