Hey guys,I have a stone stock untouched set of '66 T/A's in from a corvette buddy. These are a very nice example of what original arms in nice shape should look like. The rotors were still riveted on but will be built with flat heads to allow future access if needed. There have been threads recently on whether an old original arm should be rebuilt. Take a look and decide. These were in great shape but there was NO grease on the bearings or in the well. This car is exceptional, wish it was mine!Hope it helps answer some of the recent questions posted.This is how I recommend you remove the rivets, it has worked for me for years without any damage to the spindle flanges. You will see the rivet bodies are still in the flange to be removed later.
The rotors are like new, only a DA on the surface is required.
Wasp nest was found in the arm
Original tabbed inner seal. I like the new CR seals much better then the square edge type seal.
Parking brakes were seized and upper spring broken- very common
I drive out the spindles instead of pressing them. Works faster and safer. Without damage.
Hyatt bearings were the originals used until they became New Departure-Hyatt during the early C3 run.
No rust separation here, this is a common area to see the plate pushed out by rust.
Arm apart, all major parts are still good and will be reused. USA Timken bearings will be setup as well NO imported bearings as long as we can still get USA made.
Hope yours are as nice as these, If you want to see the final product let me know and I'll post some pic's.Good luck, keep driving them!
