1970 smog pump - NCRS Discussion Boards
1970 smog pump
  • D S.
    • March 1, 2005
    • 1551
    1970 smog pump
    What are the points deductions for not having the smog pump system installed when being judged?
  • Dick W.
    • 10483
    Re: 1970 smog pump
    Look at the judging sheets posted on the web site and take a full deduction
    Dick Whittington
    • Terry B.
      • August 31, 1999
      • 607
      Re: 1970 smog pump
      Scott,
      Not all '70's had the smog pump. Be sure to check to see if you need one. Some '70's were outfitted with some type of timing advance that eliminated the need for the smog pump. Don't recall what it is called I hope someone will chime in who knows more about 70's.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • D S.
        • March 1, 2005
        • 1551
        Re: 1970 smog pump
        Originally posted by Terry Buchanan (32872)
        Scott,
        Thanks, Terry. The car is a 1970 LT-1 and is a California car. Where do I find the judging sheets posted on the NCRS Web site that Dick referred to?
        • Jim T.
          • March 1, 1993
          • 5351
          Re: 1970 smog pump
          Eric my 1970 350/300 did not come from the factory with a smog pump. The device you refer to may be the electrical control solenoid that controlled vacuum to the distributors vacuum advance unit. Very easily to disable, just connect vacuum hose directly from the carb to the distributors vacuum advance. This full time vacuum change improves in the city gas mileage and helps engine run cooler in stop and go traffic. No need to remove the electrical controlled solenoid from the intake. The device is Transmission Controlled Spark (TCS)
          • Mark D.
            • June 30, 1988
            • 2142
            Re: 1970 smog pump
            All LT1 had smog.
            Judging Sheets...
            Kramden
