Have found an oil pan for my 1957 vette after searching for many, many months. The outside is pretty straight with very little surface rust. However the inside has some heavy pitting in the shallowest step, opposite end of the drain hole. Should I be concerned about this pitting in the inside? I will nuetralize it, then it would be in oil the rest of its life when installed....Or does this pitting present a problem on a running motor? Any help would be much appreciated. Thanks in advance!
Pitted (on the inside) Oil Pan 1957
Re: Pitted (on the inside) Oil Pan 1957
as long as it does not leak now i would use it. a real 57 oil pan is hard to find. the last one i had i put on ebay and it brought $600.00. i wish i had another one to keep for a while. do you have a pic of yours?- Top
Hi John
I have a similar condition on my '57 oil pan. If your concern is for leaks, I don't think this would be a problem. I primed and painted mine(outside) seven years ago and so far no problem. I would be more concerned about the pan rails. Some of these old pans have been over-tightened and distorted the bolt holes causing poor gasket contact.- Top
clem------
That's exactly what I would do. Then, I'd paint the inside of the pan with Rustoleum.In Appreciation of John Hinckley- Top
once you fill in the thin areas with brass i would not think you need any other protection. i know the new GM pans are power coated inside but i bet that is just for shipping and storage so they don't rust till they get filled with oil.- Top
clem------
I'm not sure if the new pans are powder coated or painted. However, whatever it is, it's done on both PRODUCTION and SERVICE pans.
As you probably know, high performance engine builders paint the lifter valley and other internal engine areas with Rustoleum or Glyptal paint. As far as I know, this is still done. I've never heard of any problems associated with it.In Appreciation of John Hinckley- Top
i was always leery of painting anything inside a engine after it had oil on i. new metal may be a different thing. i always had things like the windage tray and the inside of the pan coated with a oven baked on teflon coatingclem------
As you probably know, high performance engine builders paint the lifter valley and other internal engine areas with Rustoleum or Glyptal paint. As far as I know, this is still done. I've never heard of any problems associated with it.- Top
clem------
Yes, whenever internal painting is done, the parts have to be scrupulously clean and 100% free of any oil.In Appreciation of John Hinckley- Top
i preferred to grind the surface of the blocks in the tappet valley to smooth up that surface for faster oil return.- Top
After assembling the engine on my '54 I found that some of the pits did leak. So I removed the pan, cleaned it and poured in a high temp epoxy that covered the bottom nicely. You can also use Glyptol paint which is quite thick. You racers out there are familiar with using Glyptol to coat the rough casting areas of the heads inside the valve covers to promote return flow of oil.- Top
