54 fuel pump pressure - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    I tested my presure and comes in at 7.5 psi after two bumps. I know the spec is 3-4 psi. Will this cause constant dribble or do I need to install a regulater? Thanks for the advice.
  • Cathy S.
    • August 31, 2003
    • 293
    Re: 54 fuel pump pressure
    Yes. Anything over 5lbs will over power the needle and seat. I found rebuilding the fuel pump easy. Solved my leaking carb prob. When I tested my rebuilt pump I also had leaky carbs and 7.5lbs.
    • Guy M.
      • November 1, 1993
      • 499
      Thanks alot, did you install a regulator?
      • Cathy S.
        • August 31, 2003
        • 293
        No. My pump pressure is now 5lbs. Passenger car pumps put out more pressure, I believe the spring is different for a vette. Please verify it's been 8 years since my rebuild.
