Have the top stored in the lugs in the hatch area. Tried all three release buttons none work. Can I get to the manual release cable through the gas cap area. Any precautions?
85 hatch manual release
Tags: None
- Top
Re: 85 hatch manual release
Thanks Am 86. Did not think I could bend that much. Cable was broken Found the right end and POP. Am looking for the way to get the top storage release handle off so I can get to the latch. I assume the solenoid is in the same area. I am the original owner so I want to keep it original. Quent- Top
The latch should pull off from the top. I had a similar issue with My 88 - solenoid was bad, replaced the solenoid and it is working fine ever since. solenoid was easy to remove once you get the plastic cover off.
Best
pat- Top
Quent, can you just un-screw the front mount/mounts from the floor? might be a opition. EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
