any body tried this knock off wrench - NCRS Discussion Boards
  • George W.
    • July 31, 1998
    • 322
    Re: any body tried this knock off wrench
    Russ,
    I agree with Mike on post #8; I got one when they came out; would not make them tight; so I put a "cheater" on it
    and broke the al2 handle where it threads together; save your money and go to plan B. Good luck.
    Dr. George
    Dr. George
    • Francis F.
      • April 1, 1978
      • 420
      Regarding best method for K O 's, I have Dennis Portka's tool and feel very confident using it,but you must follow his instructions to the letter,and you will achieve the proper 450# torque....and also put a line up mark on spinner and hub as always a visual check of the line up marks will show the wheels condition. And yes a little nosieze is necessary for proper take up,and who knows ,you may want to take the wheel off for some reason,you will be glad for the nosieze.
      Francis
        Originally posted by Neil Cowen (60960)
        Re Changing from Western Repops to Orig K/Hs OK After a Variety of Opinions at the Opposite end of the spectrum I decided to use The 3 Piece Wrench from LIC to only Finish or Start a Spinner On/Off>>> Always Do a Start off or Finish on with The ****** Thumper 6#....and a Piece of Hardwood.Use 3 Piece Cast Aluminum for easier turns after ****** Thump... I have Zero Confidence in the Polyuretahne One.... Decided to use a Light Coating of Anti-Sieze as opinions were YES to use and NO not to use.. Ill go for middle ground. I have no fear Spinners will come off. Lord knows how many Xs Ive taken on and off The Western Wsheel Ones with Pins and They never loosened ( Safety Pins wouldnt stop a Wheel coming off in itself...A marker will do as well) Tyhanks for Heads Up....
        Neil -
        You don't need the chunk of hardwood - the 6# M o t h e r -Thumper hammer won't damage your spinner ears - the steel ears are a lot harder than the lead hammer face.
        • Neil C.
          • February 14, 2015
          • 50
          #19
          Your absolutely correct No Dammage so far but since I recently had KH OEM spinners Nicely Restored Still Use MT#6 with no wood but Duct Tape on ears just to be sure about not marring Thanks
