1956 Radiator - NCRS Discussion Boards
1956 Radiator
  • Reford C.
    Infrequent User
    • August 31, 2001
    • 7
    1956 Radiator
    I THINK I may have found someone to restore the original radiator in my '56, but it appears that the overflow tube is steel in the copper/brass radiator, and does not appear to be the proper configuration, and not properly attached to the side. Also, the upper tank appears to have experienced pressure swelling and he need a photo or drawing of the upper tank to be able to restore it to original appearance. Also, he would like to have a drawing or photo of a correct 56 radiator and know what the overflow is made of,and exactly where it goes and how it is attached (soldered or clips) before he begins work on it (so would I !!) I've checked all of my technical stuff and none of them show the engine side of the radiator or the overflow side. Can anyone help? I'm trying to get it ready for a Regional in 2013, and this is a major obstacle. Thanks Reford
  • Rod K.
    • 441
    Re: 1956 Radiator
    Reford,
    You have email.
