I had an intermittent problem with my brake lights not working on one side or the other. I knew it wasn't the bulbs themselves or even the brake switch because it moved from one side to the other, and they would work fine and then without moving the car or hitting a bump, if you used the turn signal then they would quit working (on one side). Use the turn signal again and they would work fine.
So I figured it was the turn signal switch. I put in a different switch (old one, from a different car) and was testing it. All lights work correctly, tail lights, brake lights and turn signals. But after using the lights, the switch is really hot. Like so hot you can't touch the leads on the back of the switch without pulling away your burnt flesh. Is that normal? I realize with two lights in back and one in the front, there's a fair amount of current going through that switch (and the ammeter dips down when you put on the brakes) but should it get that hot? I want to make sure the switch is OK before I put it back in the steering column...
