Intalling Mid-Year Windshield - NCRS Discussion Boards
  • Fred M.
    • August 31, 1998
    • 63
    I'm trying to help a friend find someone in the Daytona, FL / Central FL area that has successful experience removing and re-installing a windshield on a '64 coupe. Thanks in advance. Fred
  • Page C.
    • February 1, 1979
    • 802
    Re: Intalling Mid-Year Windshield
    Hi Fred,
    In my opinion, the safest way to remove the windshield is by cutting off the outer face of the existing rubber gasket. Then with a person on both sides of the glass, gentle work the glass out of the opening. When reinstalling, use a new rubber gasket. Some repro windshield gaskets appear to be a little "fatter" than the original which makes reinstalling the trim a pain. Others might comment on which gasket works best. I use the 3M #8509 sealant in the channel beween the rubber and the metal. The Corvette shop manual gives a good procedure for "roping" in the glass and gasket back into the frame.
    Page Cambpell
    • David L.
      • July 31, 1980
      • 3310
      Back in the late 1980's I replaced the windshields in my 1963 SWC and my 1966 convertible. Like Page suggested I cut away the old rubber gasket and installed a new GM gasket and then used the "rope" method. I had never replaced a windshield previously.
      Dave
      • Russ S.
        • April 30, 1982
        • 2161
        If you are not trying to save the windshield and the gasket is good, I personally would never cut the gasket as the repos like Page says are fatter and a REAL pain to get the trim back in place.
        PS. Again if you are not saving the w/s, I would use a half dozen or so putty knives and starting at the top of the w/s insert the knives under the rubber and lift the rubber so the top of the glass is exposed. Then with helpers gently and slowly push the w/s out from the inside while helpers on the out side keep the rubber back out of the way. Continue to work your way around to the sides of the w/s.
        • Fred M.
          • August 31, 1998
          • 63
          Thanks to all. Good info on how to save an original gasket.
          • Doug L.
            • March 14, 2010
            • 442
            I recently installed a new windshield and gasket on my '64. I cracked the original windshield when taking it out of the frame. I then needed to replace it and wanted correctly dated glass. My question to you, regardless of whether you plan to re-use your windshield or replace it, is why not get a professional to do it. I decided I didn't want to risk breaking the new glass. A local company agreed to order the dated glass I wanted from the supplier I wanted to use (Pilkington). They charged my the cost of the glass plus 10% plus an installation charge. Even though they do these every day it took 2 full days to get mine in. I used a new gasket from Corvette Rubber. It fit nicely. The problem was the lower clips. The originals were rusted and bent. I bought a new set from one vendor and fought for a full day trying to get the stainless trim to snap into place. At that point I searched this TDB and found comments about this very problem. The thread said Paragon clips would work when others would not. I ordered a set and had no problems completing the job on the second day but had to remove the glass in order to get the other clips out.
            Doug
            • Jim D.
              • 2882
              Paragon clips and a Corvette Rubber W/S = no problems.
