56 heater cover flapper door - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    How do I remove from housing?
  • Doug F.
    • November 1, 1983
    • 322
    Re: 56 heater cover flapper door
    if you mean the entire fiberglass flapper ass. from the rest of the heater, remove the fresh air cable , take out the six 1/4" head screws and pry gently, if you are installing the new c central flapper, you must destroy the old one, cut the shaft with a die grinder and a small cut off wheel on the top and bottom, watch out and don't cut your fingers or any fiberglass
    • Cathy S.
      • August 31, 2003
      • 293
      Thank you!
      • Terry B.
        • December 1, 1988
        • 111
        Or,,,,, Remove the old material from the flapper. Clean everything and paint. Close flapper and note where it contacts the housing. Now install a liner made of Velcro with adhesive to the inside of the housing and you have a new sealing surface without cutting anything. With the hose installed, who will know?
        • Cathy S.
          • August 31, 2003
          • 293
          Good idea!
