C1 Brakes - NCRS Discussion Boards
C1 Brakes
  • Bob W.
    • August 31, 1981
    • 84
    C1 Brakes
    Took car out for test drive today, everything was fine when I left. Upon return about a block from the house I lost all pedal. Got the car home and noticed the inside front drivers side drum was all wet. Time for a brake job after 20 years. Can any of the parts be bought at a regular parts store or do I have to go to some one like Paragon? Probably will need wheel cylinder kits all four and shoes. The master is bone dry now so what brake fluid should I use? Any helpful hints?
  • John F.
    • March 23, 2008
    • 2395
    Re: C1 Brakes
    See if your car has original wheel cylinders first. If so, it has the cylinder bore cast on the part. If they are off the shelf replacements, then you may as well replace again. Advance Auto or O'Riely's should have them. If they are originals and you want to rebuild, Take one front & one rear with you to Advance and get the correct size bore kits. I would also rebuild/resleeve the master cylinder if an original piece. Both of mine now have DOT-5 after completely flushing the system with denatured alcohol. Have fun!
    • Bob W.
      • August 31, 1981
      • 84
      Re: C1 Brakes
      The numbers on the wheel cylinders are 8300 front and 7565 rear. These can't be original but I assume the rear is 1" bore and the front is 1 1/8". Can anyone tell me if my assumption is correct
      • John F.
        • March 23, 2008
        • 2395
        Re: C1 Brakes
        My Delco Moraine Prod wheel cylinders are:F/L #5459528 1 3/16" boreF/R #5459527 1 3/16" boreL/R #5450649 1" boreR/R #5450649 1" boreHope this helps
        • Al E.
          • September 5, 2011
          • 313
          Re: C1 Brakes
          Do they judge these at the Nat'l level?? or any level at that case?
          • John F.
            • March 23, 2008
            • 2395
            Re: C1 Brakes
            The front cylinders are a little bigger than replacements, but as far as I know the wheels/hubs are not taken off at any judging. Whether someone can tell during a PV is unknown to me.
            • Donald H.
              • November 2, 2009
              • 2580
              Re: C1 Brakes
              To add to what John said, when I took my 60 apart for restoration I found aftermarket brake cylinders. The rears are not that difficult to find on Ebay and such. The fronts 1 3/16" bore where only used for a few years as I understand and are much more difficult to find. I was able to find correct fronts and honed and rebuilt them. They are on my car now, but I still don't have it on the road, so I hope they work. Since then I was also able to find a NOS set of fronts for a reasonable price and have them as spares.
              If you do a search on C1 Brake Cylinders you will also find information on used 1 3/16" cylinders made for International Truck as a substitute if you want to keep the 1 3/16". My uderstanding is that the biggest difference with using the 1 3/16" on front is pedal pressure when applying the brakes is less then when using 1" cylinders.
              I do not believe that the wheels are removed at judging events. I was the the Fla regional and at least for Flight judging the wheels were never removed on any of the cars.
              Don Harris
              Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
              • Richard T.
                • February 1, 1979
                • 858
                Re: C1 Brakes
                When resleeving the 528 and 527 front cylinders with the 1 3/16 bore do you have the sleeve bored to 1 3/16 ". If so where do you get wheel cylinder kits for these? NOS ? Or are there aftermarket kits available? I found my original 62 wheel cylinders along with a few spares and would like to sleev and re use them. Rich
                • Donald H.
                  • November 2, 2009
                  • 2580
                  Re: C1 Brakes
                  Not sure what your asking in your first part - the 1 3/16" bore cylinder should be 1 3/16" bore. If you have it sleeved, then the bore again will end up being 1 3/16".
                  As I recall, I got my rebuild kits for the fronts (1 3/16") bore from NAPA and rear 1" bores from NAPA. But RockAuto also carries a rebuild kit for 1 3/16" bore.
                  Don Harris
                  • Bill B.
                    • December 1, 1993
                    • 192
                    Re: C1 Brakes
                    Related topic, when re-sleeving master cylinder, what is the best metal? Also has anyone ever re-sleeved wheel cylinders? I'm curious, thanks Bill
                    • John F.
                      • March 23, 2008
                      • 2395
                      Re: C1 Brakes
                      I got the rebuild kits from Advance Auto parts. They can get the 1 3/16" kits. Do not throw away the pistons. I had stainless steel sleeve put in my MC.
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Re: C1 Brakes
                        Be careful about resleeving anything. Only do this if you can't clean the bore up with a hone.
                        • Donald H.
                          • November 2, 2009
                          • 2580
                          Re: C1 Brakes
                          If do some searching you will find various opinions of brass versus stainless steel. I had my master cylinder sleeved because it was so heavily pitted and the place that did it used stainless. Others use brass.
                          Don Harris
