Restoration process - NCRS Discussion Boards
Restoration process
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Restoration process
    Todd,
    Contact Bill Mock - he is a NCRS member and posts in the DRIVELINE and Hemmings
    Rt. 2, Box 140
    Bartlesville, OK 74006
    Phone: 918-333-0748
    mockauto@aol.com
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Paul J.
      • September 9, 2008
      • 2091
      Originally posted by Todd Lloyd (49373)
      Paul,
      Thank you for your input, I do appreciate everyones advice. So you are saying it is ok to work on the motor and once finished it will be ok sitting? It is out and would be the easiest part to start on until I get the rest of the car prepped and ready to begin restoring. I just found out my Water pump is not original, and it is a date coded item. I love the hunt.
      Todd
      If you keep the motor indoors in an area that doesn't have large and rapid temperature swings, it doesn't matter if a rebuilt motor sits. There is a time limit as to how long the motor oils and assembly lube used in the rebuild will last, but it is several years. If you use a good start-up procedure, any ill effects will be unmeasurable.
      Paul
