Painting small letters on wheelcover knockoff
Re: Painting small letters on wheelcover knockoff
Bill,
There are a couple of methods to use. One would be to use
Krylon Flat Black and mask off the outer area. Then spray and let dry. Then use lacquer thinner, a rag and a Popsicle stick to remove the paint from unwanted areas. The other would be to get a small bottle of Flat Black model paint from Hobby Lobby and a fine pointed brush. Brush in the paint, let dry, and use the removal technique above. With a little patience you should have a pleasingly improved result.
Good luckHarry Ledgerwood
Member #2901
Current Region VII Director (2021 thru 2023)
- Top
Another method that I have used on recessed areas of emblems is to thin the paint and use a hypodermic
needle to fill the recesses. I usually get needles designed for large animals from the vet.
After the paint dries, I may add a second application if needed. Seems to work on most emblems.
Dave
#3627
- Top
